creating a progress filter
w4qnw
#1 Posted : Saturday, December 14, 2019 10:52:24 AM(UTC)
I am concentrating on WORKED ALL PREFIXES and now
at a point of searching through my large 100k+ entries
for PREFIXES WORKED (W) BUT NOT CONFIRMED (F).
it is a huge time consuming job....considering the
same process for 6 bands
QUESTION: is there a filter that can produce a
matrix (list) showing ONLY "WORKED" (W) prefixes band by band...??????????
with that available i can concentrate on exactly which qso to contact
the operator for help.
as of NOW I CAN scroll the "progress for PFX" and see
what im looking for but that is a much more time consuming
job.
thanks
today is 12/14 so in advance HAPPY HOLIDAY GREETINGS TO
ALL AND HOPES FOR CONTINUED GOOD HEALTH IN THE YEARS AHEAD.
#2 Posted : Saturday, December 14, 2019 4:49:16 PM(UTC)
There are a few ways to do this with filters either on the LOG or as a report. Maybe try a report as you can print a hard copy to use as a working document.
Run AWARDS report, select PFX for the specific award, for sort order try BAND/MODE/VALUE. The next screen will list the Select Criteria, click instead on the funnel icon to the right which will launch the Filter Screen, make field name QSL Rcvd equal W, and, assuming you use LoTW, make LoTW Rcvd not equal F. This will filter the report to give you only QSO's worked, by band, mode, and in PFX order. Once you go through this you'll see you have many options for the criteria, both in filtering the report as well as the reports sort order.
Again, this is just one of many ways, others in the forum may chime in with alternative solutions.
Let us know if this works and if not give another scream !!
73 de Brad, N8GLS
#3 Posted : Monday, December 23, 2019 1:43:45 PM(UTC)
Thanks -- Merry Christmas to you and all.
Try the CARDS NEEDED FOR AWARD report. It gives the W-status QSOs for each band for each prefix. Be sure NOT to select a band.
Sorry for the delay in my response.
