Posts: 41 Location: bluffton, sc
Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
with DX activity down on HF PHONE I've taken to tracking the CQ/LOTW WPX
EXAMPLE DL1 DL2 DL3 DK1 DK2 DK3 ETC ETC
maybe somehow an large established log can separate the prefix and somehow incorporate it LIKE DXCC we could see immediately if W (worked) or R (confirmed/received)
the current progress template could be used.
(ha if the option is already available im missing it)
Ive got over 2500 prefixes so far and now its impossible in a WPX or any contest to see my need/worked list in real time.
LOGic is set up to track WPX by default. It uses the user-defined PFX field to do this. So click Awards/Progerss List. The award is PFX. Click NEXT.
You can use the Progress1 or Progress2 window to show it in real-time as you log or browse thru your log form -- just like any other award.
If there is any problem, let me know and I can walk you thru checking the setup.
Tnx for using LOGic.
Dennis....PFX (dxcc country) is understood
requested WPX individual prefixes within the country i.e. Serbia YU station assigned call YU1 YU2 YU3 YU4 ETC
data base progress similiar but adding (STATION PREFIX) NOT COUNTRY
see CQ mag and LOTW totally separate major award challenges
only thinking that this might be done with the addition of another user field WPX not dxcc PFX
Right -- the PFX that LOGic logs is from the callsign. The DXCC field has no effect on it. File Attachment(s): pfx.png (64kb) downloaded 154 time(s).
