Import ADIF - PWR is wrong
#1 Posted : Thursday, February 23, 2012 6:46:26 AM(UTC)
When importing a ADIF to LOGic9 the power is set to 1000. I type 100 in the window that prompts for Contest ID and Pwr but after the import 1000 is shown in the log.
#2 Posted : Thursday, February 23, 2012 8:03:05 AM(UTC)
GM Kyle--
I checked the import code and it doesn't appear to be doing anything with the default power setting used when logging.
Open your ADIF file in Notepad and make sure that PWR is not specified there. The value entered in the prompting window does not override anything that is in the file.
If you WANT to override what is in the ADIF file, simply use mass replace to change PWR: to PWRX:
#3 Posted : Thursday, February 23, 2012 8:26:37 AM(UTC)
Once I opened the ADI file I knew it had to be something I missed in N1MM. I changed the Station Data and now all is well.
Thanks and have a good day!!
Kyle
