Logic 9 install and Radio Interface setup problems
WD4ASP
#1 Posted : Wednesday, February 22, 2012 10:35:59 PM(UTC)
I got the following error when installing Logic 9:
Error #1806
Msg: SQL: Column 'CALLSIGN' is not found.
Line # in .\UPDATES\RUNONCE_TABLES.PRG':262
Code:
I continued the install and the rest of it went smoothly. Do I need to be concerned about this error?
I then ran Logic 9 and when setting up the Radio Interfaces I got the following error:
Class definition ICOM735, ALSO OMNI-VI is not found.
I exited the program and restarted it and got the following msg:
Error 1733 "Class definition ICOM735, ALSO OMNI-VI is not found" has occurred in program LOGICAPP.LOAD_RADIOS, line 54
Attempt to continue?
I answered Yes.
I set up my FT-736R radio interface without any problem and it appears to be working.
Fred
#2 Posted : Wednesday, February 29, 2012 6:07:58 PM(UTC)
The error from RUNONCE_TABLES is nothing to worry about.
For the Icom735, use the new non-legacy driver ICOM BASIC. (the .038 update should fix the CLASS NOT FOUND error if you need to use the old drivers for some reason.
