LOGic Forum
LOGic Support
All Other
Spreading Windows Across Multiple Displays
Posts: 6 Location: Loganville, GA
Wondered it anyone has multiple displays at their operation position. I have several ham software programs that will allow moving windows to an adjacent display. It would be nice if you could do that with Logic 9. Such things as the Spot Log and the Browse window would be nice to have on the adjacent display. Just a thought.
I can also open separate browsers between the two displays.
Dan, W4EA
Have at it. Right-click the form that you want to put in a different monitor. Click IN WINDOWS DESKTOP. Close and reopen the form or restart LOGic.
Search Help for Multiple Monitors and look at Basic Form Customization for more info.
Sorry about that Dennis, somehow I missed that in the User Manual. I need to get used to using the Help within the program, it elaborates very well. I did make the changes and that is great. Apparently "Browse" is the same as the Log, a component of" and therefore cannot be split out from the same page. No problem, I re-arraigned the various Forms and it works just great.
Dan
Yes, the log window can be moved out. Go to Log/Form Properties. The Browse and Data Entry parts of the log form must both go IN WINDOWS DESKTOP or both in the LOGic window, however.
I should have realized that you need to do the main Log Form. I did try it and didn't like the results as it minimizes each time you access a different form. See what you mean.
Dan
Here'something to try. Click the boat anchor button. By default the two forms are attached and minimize together. But you can detatch them and minimize and position them separately. (They still have to both be either in or out of the desktop as I mentioned).
If they are really minimizing when you select some other form, we have a problem. They should not minimize automatically.
LOGic Forum
LOGic Support
All Other
