License Update
NU1B
#1 Posted : Tuesday, September 11, 2018 6:52:10 AM(UTC)
Hi Dennis
I downloaded the copy of Logic 9 sent in your email. I installed the program nd started Logic. I got the following error message:
Error 1426OLE error code 0X8002000e invalid number of parameters has occurred in program
LOGICAPP.LOAD_RADIOS, Line 243
Attempt to Continue
When I click on yes, my Logic desktop comes up but when I try to perform a task like import for LOTW, I get an error message again and the program shuts down
Please let me know how to fix this issue
thanks
Steve, NU1B
NU1B
#2 Posted : Tuesday, September 11, 2018 7:11:08 AM(UTC)
The error message I get when I TRY O IMPRT FRO lotw AND Eqsl IS
ole ERROR CODE 0x80020006 UNKOWN NAME has occurred in program
IMPORTADIFRECORF.IMPORT, LINE 33
Attempt to conture
If I click on yes, I get the same error message with Line 34. If I click on no, the program shuts down
Steve NU1B
#3 Posted : Tuesday, September 11, 2018 11:35:19 AM(UTC)
Hi Steve:
Thanks for your note. Sorry for the trouble.
Please try clicking Help/Check for Updates, and get the latest update (9.1.37).
If you can't get LOGic to run long enough to get to Help/Check for Updates, there is an UPDATER option in the Windows Start Menu under LOGic.
Let me know if you continue to experience problems.
NU1B
#4 Posted : Tuesday, September 11, 2018 11:48:29 AM(UTC)
Hi Dennis
When I installed 9.1.37 after installing the file I downloaded from the email, Logic works fine with errors
Thanks for help
Steve, NU1B
#5 Posted : Tuesday, September 11, 2018 12:11:29 PM(UTC)
You are most welcome. Again, I apologize for the problem.
