Groups: Administrators, Beta Testers Posts: 3,260  Location: Auburn, GA Thanks: 1140 times Was thanked: 555 time(s) in 465 post(s)
Hi Mauro:
Not in LOGic or any other program that I am aware of. Output to the printer is first written to disk, them dumped to the printer independent from the application that generated it.
I have a printer that prints two sides. The driver has adjustable delay to let the ink dry. Check the printer driver. Is it a 2-sided printer? If so, and you don't want two sides printed, you could always set LOGic up to print a blank second side.
