ver...1.37 and Kenwood radio polling
KD0PO
#1 Posted : Sunday, August 12, 2018 10:44:48 AM(UTC)
dokxray
for what it's worth, with polling OFF the software does NOT follow my
TS-990.
No big deal, I just turned it back on and it does follow freq.
Ray
#2 Posted : Sunday, August 12, 2018 5:29:26 PM(UTC)
Thanks for letting me know. I haven't actually tested it on a Kenwood. Just a K3. But it should be the same.
If you want to bother, turn off polling. Turn on data logging on the first tab of the Misc Ham Setup screen. Close that form, operate the kenwood for a minute. Turn off data logging. Send me the data log file. It will be in the TMP folder inside where LOGic is installed (C:\program files (x86)\LOGic\tmp unless you installed it elsewhere).
KD0PO
#4 Posted : Monday, August 13, 2018 10:07:43 PM(UTC)
dokxray
I'll be happy to do that.
Ray
1 user thanked KD0PO for this useful post.
WN4AZY on 8/14/2018(UTC)
KD0PO
#3 Posted : Saturday, September 1, 2018 11:03:42 AM(UTC)
dokxray
18-09-01 10:56:04.21 LogComment
18-09-01 10:56:04.21 LogComment ------------------------------------------------------------------------------
18-09-01 10:56:04.21 LogComment LOGic Version: 9.1.37
18-09-01 10:56:04.21 LogComment Class: kenwood_850
18-09-01 10:56:04.21 LogComment Modlue: rigifc9.vcx
18-09-01 10:56:04.21 LogComment Descr: Kenwood 850,950,990,450,2000,590,Flex 6000 & other rigs w/o SP cmd
18-09-01 10:56:04.21 LogComment Notes: Turn on polling for TS-2000 and TS-590.
18-09-01 10:56:04.21 LogComment Ifc#: 54
18-09-01 10:56:04.21 LogComment Poll: May poll
18-09-01 10:56:04.23 LogComment Poll interval: Not polling
18-09-01 10:56:04.23 LogComment Port: COM3
18-09-01 10:56:04.23 LogComment Baud: 115200
18-09-01 10:56:04.23 LogComment Stop Bits: 1
18-09-01 10:56:04.23 LogComment DTR: True
18-09-01 10:56:04.23 LogComment RTS: True
18-09-01 10:56:04.23 LogComment Overlapped: False
18-09-01 10:56:05.94 LogComment Mfgr: WinChipHead
18-09-01 10:56:05.94 LogComment Device ID: MF\PCI#VEN_1C00&DEV_3470&SUBSYS_34701C00&REV_10\5&A3057A2&0&00E6#CHILD0001
18-09-01 10:56:05.94 Write AI1;
18-09-01 10:56:05.94 tx WriteBinary 41 49 31 3B
18-09-01 10:56:05.94 LogComment RThreshold set to 1. It was 0
18-09-01 10:56:05.96 LogComment RThreshold set to 0. It was 1
18-09-01 10:56:05.96 rx DiscardInBuffer
18-09-01 10:56:05.96 Write IF;
18-09-01 10:56:05.96 tx WriteBinary 49 46 3B
18-09-01 10:56:05.98 rx ReadTo ; ?;
18-09-01 10:56:05.98 LogComment RThreshold set to 1. It was 0
18-09-01 10:56:05.98 rx WaitForData ; IF00014310000 100000000020000000;
18-09-01 10:57:41.86 Write AI0;
18-09-01 10:57:41.86 tx WriteBinary 41 49 30 3B
18-09-01 10:57:41.86 LogComment RThreshold set to 0. It was 1
18-09-01 10:57:41.86 LogComment Disposing
sorry this took so long, I work out of town and haven't had access to the rig
Ray
#5 Posted : Thursday, September 6, 2018 11:18:29 AM(UTC)
I see the rig is sending the AI1; command, which is supposed to cause the radio to automatically send information when you chance freq and mode, hence no need to poll. The rig is ignoring it for some reason. I would send a copy of the log to Kenwood and see what they suggest.
PS Here is the data from a K3 (which uses identical code as the Kenwood for receiving data). Note LOGic sends AI1;, then IF; to REQUEST the data to refresh the display on startup. Then you see line after line of data when the rig is tuned.
18-07-17 15:14:32.09 LogComment
18-07-17 15:14:32.09 LogComment ------------------------------------------------------------------------------
18-07-17 15:14:32.09 LogComment Class: elecraft_k3
18-07-17 15:14:32.09 LogComment Modlue: rigifc9.vcx
18-07-17 15:14:32.09 LogComment Descr: Elecraft K3, Smart SDR
18-07-17 15:14:32.09 LogComment Notes:
18-07-17 15:14:32.09 LogComment Ifc#: 55
18-07-17 15:14:32.09 LogComment Poll: May poll
18-07-17 15:14:32.09 LogComment Poll interval: Not polling
18-07-17 15:14:32.09 LogComment Port: COM10
18-07-17 15:14:32.09 LogComment Baud: 38400
18-07-17 15:14:32.09 LogComment Stop Bits: 1
18-07-17 15:14:32.09 LogComment DTR: False
18-07-17 15:14:32.09 LogComment RTS: False
18-07-17 15:14:32.09 LogComment Overlapped: False
18-07-17 15:14:32.10 LogComment Version: 9.1.36
18-07-17 15:14:32.11 Write AI1;
18-07-17 15:14:32.11 tx WriteBinary 41 49 31 3B
18-07-17 15:14:32.11 rx DiscardInBuf
18-07-17 15:14:32.11 Write IF;
18-07-17 15:14:32.11 tx WriteBinary 49 46 3B
18-07-17 15:14:32.11 rx ReadTo IF00050312999 -000000 0005000001 ;
18-07-17 15:14:33.06 rx WaitForData IF00050312999 -000000 0005000001 ;
18-07-17 15:14:34.07 rx WaitForData IF00050312999 -000000 0005000001 ;
18-07-17 15:14:35.07 rx WaitForData IF00050312999 -000000 0005000001 ;
18-07-17 15:14:36.07 rx WaitForData IF00050312999 -000000 0005000001 ;
18-07-17 15:14:37.07 rx WaitForData IF00050312999 -000000 0005000001 ;
18-07-17 15:14:38.09 rx WaitForData IF00050312999 -000000 0005000001 ;
18-07-17 15:14:39.09 rx WaitForData IF00050312999 -000000 0005000001 ;
18-07-17 15:14:40.09 rx WaitForData IF00050312999 -000000 0005000001 ;
18-07-17 15:14:41.10 rx WaitForData IF00050312999 -000000 0005000001 ;
18-07-17 15:14:42.10 rx WaitForData IF00050312999 -000000 0005000001 ;
18-07-17 15:14:43.10 rx WaitForData IF00050312999 -000000 0005000001 ;
18-07-17 15:14:44.12 rx WaitForData IF00050312999 -000000 0005000001 ;
18-07-17 15:14:45.13 rx WaitForData IF00050312513 -000000 0005000001 ;
18-07-17 15:14:46.13 rx WaitForData IF00050312485 -000000 0005000001 ;
18-07-17 15:14:47.13 rx WaitForData IF00050312485 -000000 0005000001 ;
18-07-17 15:14:48.13 rx WaitForData IF00050312485 -000000 0005000001 ;
