new band setup in v 9.1.37
N7IP
#1 Posted : Saturday, August 11, 2018 2:26:12 PM(UTC)
Dennis, this update seems to have overwritten my band setup. I had previously identified FT8 segments but they are now gone. Any way changes to this table can be called out as an option? Any way to restore my previous band setup?
Also, the comment field in the spot log is expanded. Looks like this:
cw 19 db 25 wpm cq 2007z wa
whereas previously the content ended with the "cq". Any way to delete the redundant time and state?
BTW, the new com port software is a great improvement. It enables me to use the K3 driver rather than Omnirig thru my Remote Rig connection. Excellent!
Bob N7IP
#2 Posted : Sunday, August 12, 2018 8:03:25 AM(UTC)
Hi Bob,
also I modified the segments for FT8 into the Band table, but the new version .37 left everything unaltered.
This is my experience.
#3 Posted : Sunday, August 12, 2018 8:28:01 AM(UTC)
We don't overwrite the band table. Not sure how that happened. The only way to get it back would be if you have a backup of your whole LOGic folder.
If you or someone can send me your band table with FT8 freqs defined, I will add it to the master product.
I did some work on the parsing of spot comments because it was losing stuff. I see I still have more to do to that. Where are you getting your spots from?
Thanks. We had to do something with all these virtual ports etc. It was a monumental task, but worth it, it appears!
N7IP
#4 Posted : Sunday, August 12, 2018 1:38:35 PM(UTC)
I use VE7CC for spots. Logic is still has trouble logging onto this site. See my setup attached. It times out 9 out of 10 times at startup. Then, when I disconnect and reconnect, it almost always logs on fine.
Bob
n7ip telnet.pdf (502kb) downloaded 92 time(s).
#5 Posted : Sunday, August 12, 2018 2:08:34 PM(UTC)
I do not know if my table is rightly formulated.
I tried two systems:
One: enter modes with frequencies in sequence.
Two: enter frequencies for FT8 without a sequence.
I believe the correct form is the first one.
I hope to have not created problems in the archives, but the spot log seems to work.
Only problem when I click on the spotlog to put the qso in the log gives me error because it does not find FT8.
I did only one test because the qso in FT8 I transfer them with ADIF files and everything proceeds correctly.
Attached to the message my Band Table file.
BANDMSTR.zip (2kb) downloaded 106 time(s).
#6 Posted : Sunday, August 12, 2018 4:56:31 PM(UTC)
N7IP:
Note the text that comes back from the cluster when you try to log in:
*** Connected to VE7CC-1:
Greetings from the VE7CC-1 cluster.
Located near Vancouver BC
Running CC Cluster software version 3.116bz
* Please login with a callsign indicating your correct country *
* Portable calls are ok. *
New commands:
set/skimmer turns on Skimmer spots.
set/noskimmer turns off Skimmer spots.
set/nobeacon turns off spots for beacons.
set/beacon turns them back on.
For information on CC Cluster software see:
http://bcdxc.org/ve7cc/ccc/CCC_Commands.htm
AR User program now at ver. 2.447
Please enter your call:
login:
Your first prompt is
CALL:
It should be
LOGIN:
You don't need to worry about trailing spaces (LOGIN:_) any more.
My setup is in the attached screen shot.
N7IP
#7 Posted : Sunday, August 12, 2018 6:19:02 PM(UTC)
Thanks very much, Dennis!
Bob
N7IP
#8 Posted : Monday, August 13, 2018 3:51:29 PM(UTC)
Changing to your setup still does not work. Here's the transcript and attached is the setup. If I disconnect and then reconnect, it works. That was also true when the first line of the setup was "call:"
login: *** Connected to VE7CC-1:
New commands:
LOGic> Waited for LOGIN: to be sent by host, but it was not.
LOGic> Check Setup.
n7ip telnet.pdf (439kb) downloaded 100 time(s).
#9 Posted : Monday, August 13, 2018 4:30:23 PM(UTC)
Hi Bob,
this is my setup and i have no problem. (Screenshot)
My Telnet response …:
New commands:
login: IK0CHUIK0CHU
Hello Mauro.
Cluster: 402 nodes 829 Locals 4540 Total users Uptime 37 days 15:41
WWV disabled To enable, enter "SET/WWV".
IK0CHU de VE7CC-1 13-Aug-2018 2124Z CCC >
DX de HB9JCB-#: 10113.1 S57V CW 13 dB 26 WPM CQ 2124Z
DX de HB9DCO-#: 3540.0 SF7YT CW 13 dB 22 WPM CQ 2124Z
DX de DO4DXA-#: 7024.0 I1ULJ/8 CW 22 dB 23 WPM CQ 2124Z
DX de HB9DCO-#: 7027.2 G4DVK CW 08 dB 18 WPM CQ 2124Z
WN4AZY on 8/14/2018(UTC)
#10 Posted : Tuesday, August 14, 2018 5:04:46 AM(UTC)
N7IP: The cluster isn't sending the login: prompt, at least not within the default 10 seconds that it waits. No problem here tho over approximately 20 tests.
You can enter more time in setup.
IK0CHU: Turn off LOCAL ECHO. That will prevent it from doubling any info entered by you or auto login.
This page was generated in 0.095 seconds.
