How do I access Prefix DIRECTION in reports?
#1 Posted : Monday, February 13, 2012 6:32:18 AM(UTC)
G'Day,
I am using Logic 9.0.34
I see from the Logic 9 Help that DIRECTION is no longer held in the PREFIX table, but calculated on the fly for the Info form.
As shown in the PREFIX_LOOKUP_DEMO report, I use "getprefixinfo(call, qso_date)" in the detail band "on entry" to report DIRECTION for the call prefix.
Unforunately, in Logic 9, this no longer works as the DIRECTION field no longer exists in the PREFIX table.
Is there a function I can call to calculate direction for a prefix "on the fly" in a LOG report?
#2 Posted : Monday, February 13, 2012 2:02:34 PM(UTC)
Hi Peter:
The DX & Direction is not a simple function call. It would probalby be possible to do in the report writer, but would be messy.
This is your custom report I presume?
Look at our GRAYLINE and BEAM HEADING CHART to see how to do it. It is in the Commands section, FILE OPEN. Here is a copy of the code:
select *, cast(0 as integer) as dx, cast(0 as integer) as direction from prefix order by dxcc into cursor prefixcursor readwrite
scan
whereitis.setcoords(lat, lon)
replace dx with whereitis.dxmiles, direction with whereitis.bearing
endscan
Be sure to select NONE for the View tab. Otherwise the commands won't run.
FYI, WHEREITIS is an object in a global memory variable. LOGic uses it for all DX and Direction calculations from your QTH.
You report from a file named PREFIXCURSOR. But if the report is done properly (no reference to the main file) it should run correctly without additional changes.
Tnx for using LOGic.
