LOGic Forum
LOGic Updates
LOGic 9 Updates
Help, Check for updates crashes LOGic
Posts: 32 Location: Minnesota
When I check for updates, under Help, Logic crashes. I get an error message about There was no endpoint listening at .... No matter what selection I make, Logic crashes. Is there another way to check for updates?
The error message makes it sound like you have no internet connection or our server is down (which it is not).
You can run the LOGic updater outside of LOGic. Look for UPDATER or LOGIC UPDATER under LOGic in the Windows Start Menu. But I suspect you will get the same results.
Try temporarily disabling any virus checker or internet protection software. If that turns out to be the case, you can probably add an exception for InstallLogicUpdate.exe
LOGic Forum
LOGic Updates
LOGic 9 Updates
