Help, Check for updates crashes LOGic
N0AT
#1 Posted : Tuesday, March 13, 2018 8:06:58 AM(UTC)
When I check for updates, under Help, Logic crashes. I get an error message about There was no endpoint listening at .... No matter what selection I make, Logic crashes.
Is there another way to check for updates?
#2 Posted : Wednesday, March 14, 2018 7:48:13 AM(UTC)
The error message makes it sound like you have no internet connection or our server is down (which it is not).
You can run the LOGic updater outside of LOGic. Look for UPDATER or LOGIC UPDATER under LOGic in the Windows Start Menu. But I suspect you will get the same results.
Try temporarily disabling any virus checker or internet protection software. If that turns out to be the case, you can probably add an exception for InstallLogicUpdate.exe
