Importing ADI files (part 2)
#1 Posted : Thursday, January 18, 2018 8:28:39 PM(UTC)
logging a qso in real time the record contains all the fields name without space as |CONT:EU|SRX:GRI| etc ....
importing an ADI file the record contains spaces as | CONT:EU| ITUZ:28| etc .... and if i need to modify something the record update is right with no space.
Many records, in my archive, have |LAT:????|LON:????. How delete to save spaces?
In the last CQBBI contest I imported the ADI file into Logic with all the qsos but the WAIP variable did not fill the field into the logmain form.
I tried several times but I had to update the WAIP field (formerly I PROV) in all 336 QSOs manually.
I could not understand why.
For your information I am attaching the file that I have imported so that you can understand the cause and a screenshot of IQ3UD (look the adif file there are all the informations).
Thanks 73's de IKØCHU Mauro
cqbbi_2018.zip (6kb) downloaded 118 time(s).
#2 Posted : Sunday, January 21, 2018 8:27:06 PM(UTC)
Tools/misc utilities/fix stuff should do it.
Thanks for sending the ADIF file. They imported no problem here. Make sure that WAIP is in tools/setup/log fields. Make sure that IMPORT and EXPORT is turned on in the ADIF tab.
Use the USERFIELDS log form to look at the raw user-defined field data and see if WAIP is there.
