CQZ and ITUZ not recognized
N7IP
#1 Posted : Friday, December 22, 2017 4:59:59 PM(UTC)
Recently I have been getting errors when I run the "update awards progress" utility. Several entries for CQZ and ITUZ that are less than 10 have been entered as two digits, such as 05 and 06. This has resulted in the error "values not recognized." Can Logic accept these as simply "5" or "6"? I added the two digit numbers as valid entries, which solved the problem. But it may have created a problem elsewhere.
Also, if I do make changes to the list of valid values or modes (such as adding FT8), are these retained if I install an update? How do I retain them if I do a re-install?
Bob, N7IP
WN4AZY on 12/23/2017(UTC)
#2 Posted : Monday, December 25, 2017 9:14:51 AM(UTC)
Please get the latest 9.1.26 update. Be sure to run FIX STUFF as per the instructions with the update to correct the data that was improperly imported.
Your modes table (and most of LOGic's data) is not affected when you install an update. The only way to install a new factory modes table would be to delete yours then install the update. The factory version is concurrent with the latest LoTW config file and now contains FT8 BTW. Look at the notes for the last few updates (help/check for updates).
Merry Christmas & 73,
#3 Posted : Wednesday, December 27, 2017 3:59:27 PM(UTC)
Was thanked: 241 time(s) in 207 post(s)
9.1.26 does not import grid square from WSJTX_LOG.ADI
WN4AZY on 12/28/2017(UTC)
#4 Posted : Thursday, December 28, 2017 6:01:47 PM(UTC)
Thanks for letting me know. Get 9.1.27.
wa4pgm on 12/29/2017(UTC), KA1J on 4/5/2018(UTC)
#5 Posted : Friday, December 29, 2017 6:33:40 PM(UTC)
9.1.27 works great, thanks!!
Happy New Year!
WN4AZY on 12/30/2017(UTC), KA1J on 4/5/2018(UTC)
