SPOT Log connection errors
K1ESE
#1 Posted : Saturday, August 5, 2017 10:40:39 AM(UTC)
If I open the form Telenet1, the program searches unsuccessfully for "tnt32.ocx" which is not on my computer. That will end the program.
If I use the form WebCluster DX Summit, the program shows "Error 1426". Later I get the error, the letters PRE in html brackets plus "not found in the URL correct? Are you connected to the Internet?" yes, I am connected to the internet.
Where can I get tnt32.ocx? How can I get the WebCluster DX Summit to work? What is error 1426?
73 de K1ESE
John
#2 Posted : Saturday, August 5, 2017 6:30:35 PM(UTC)
Hi John,
Not sure whats going on with your setup but I believe I would re-install LOGic. I am using LOGic 9.1.20 and I use Telnet almost everyday. I tried WebCluster DX Summit with no issues.
Back up your log to be safe and then reload LOGic. I also recommend you update to the latest 9.1.20 and let us know.
73 Kyle, WA4PGM
WN4AZY on 8/7/2017(UTC)
K1ESE
#3 Posted : Sunday, August 6, 2017 6:34:00 AM(UTC)
Kyle -
Thanks for the idea. I only have an old installed version and the 9.1.1 update on my computer. I have copied my license to a thumb drive for safe keeping.
Where do I get the full install of version 9?
I assume I -
backup important files (which ones?)
uninstall the current version (license safely on thumb drive)
install the full version 9 (I don't have)
install the 9.1.1 update (I do have)
copy my license into that directory
restore the important files.
That sound right?
John K1ESE
#4 Posted : Sunday, August 6, 2017 7:47:43 AM(UTC)
What version of LOGic are you using now?
I think tnt32 is a windows file so reinstalling LOGic as I wrote in my first reply may not correct the issue.
Have you tried to use telnet in Windows?
Click Start and in the Search box type "telnet" (sans quotes)
A telnet box should pop up.
Type in "o dxc.w4ml.net" (sans quotes)
You should get a prompt asking for your callsign??
If this doesn't work check to make sure the Telnet Client is turned on.
Click Start > Control Panel.
Click Programs and Features.
Click Turn Windows features on or off.
In the Windows Features dialog box, check the Telnet Client check box.
Click OK. The system installs the appropriate files. This will take a few seconds to a minute.
From this point if Telnet is not working you may have other issues that Dennis might have to assist. I don't think you can update to 9.1.1 without the full version on 9 being installed. After 9.1 is installed a update is very easy by Click Help>Check Updates.
Be sure to always keep a backup of your "log".
Kyle, WA4PGM
K1ESE
#5 Posted : Sunday, August 6, 2017 1:33:00 PM(UTC)
Kyle -
tnt32.0cx is not a Microsoft module, it's from a company with a name like DEV something. So, I assumed it is from a control Dennis is using.
Telnet works well with other loggers. I have been using Spotcollector for years using telnet.
Dennis, how about some help?
73 de K1ESE
John
#6 Posted : Monday, August 7, 2017 3:48:38 AM(UTC)
Hi John,
if tnt32.ocx is necessary and there is not in your HD try to repair. A too simplex solution? HI
http://www.dllrepairerro...e-errors/TNT32.OCX.html
73's Mauro IKØCHU
K1ESE
#7 Posted : Monday, August 7, 2017 5:18:40 AM(UTC)
Thanks for the ideas. None of the three ways worked. SFC SCANNOW showed no errors. DISM said all was repaired. DLLEscort could not find tnt32.ocx on its servers. The error persists.
Thank you for trying to help.
73 de K1ESE
John
#8 Posted : Monday, August 7, 2017 5:58:52 PM(UTC)
Hi John:
All of the updates now and including the 9.1.1 are full installs of LOGic. You are doing the right thing with the license file. You could install the update into a new computer, then copy your license file to the LOGic folder, and have a complete functioning copy of LOGic.
TNT32.OCX was discontinued as of LOGic 9.1.3. It SHOULD be part of the 9.1.1 update. But I will dig up a copy if it and attach to this post. Be sure to unzip it. I doubt it will let me upload an OCX. Copy it to c:\windows\syswow64. If you don't have a syswow64 folder, copy it to c:\windows\system32. You will need to register it. Run the command prompt as administrator. I'm assuming Win 10 here, but 8 & 7 should be similar. Type CMD at the windows search box. Right-click COMMAND PROMPT and RUN AS ADMINISTRATOR. CD \windows\syswow64. Type REGSVR32 TNT32.OCX Let me know if you need help with any of this.
DX Summit is not going to work on 9.1.1. They changed their web site. We are getting away from using browsers where ever possible, and fortunately DX Summit has a JSON and XML feed which LOGic now uses.
I'm biased I know, but I do think the updates are worth the money.
http://www.hosenose.com/...amp;PrimaryCatID=44&
tnt32.zip (26kb) downloaded 127 time(s).
K1ESE
#9 Posted : Tuesday, August 8, 2017 7:56:08 AM(UTC)
Dennis -
Several attempts, including a reboot, failed to register tnt32.ocx. Windows keeps saying It can't find the module even though IO see it if I do DIR TNT32.OCX at the command prompt in the windows\syswow64 directory.
Rather than spend time working on this, I will pay for the update and get version 9.1.3.
John k1ese
1 user thanked K1ESE for this useful post.
WN4AZY on 8/9/2017(UTC)
#10 Posted : Wednesday, August 9, 2017 8:37:30 AM(UTC)
Thanks John, not sure why it won't register.
