Text export of grids confirmed
K6FW
#1 Posted : Friday, June 9, 2017 9:28:58 PM(UTC)
Is there a way to export a list of grids confirmed to a text file by mode? For example satellite grids confirmed. Only want grids and no other fields in the text file. Want to use the text file to import into GcmWin. Thanks, Frank K6FW
#2 Posted : Wednesday, June 14, 2017 7:54:47 PM(UTC)
These three commands will do almost what you want, (Tools/Advanced/Database Commands:
USE LOG
SELECT DISTINCT GRID FROM LOG WHERE !EMPTY(GRID) AND (LOTW_RCVD="F" OR QSL_RCVD="F") AND MODE="CW" ORDER BY GRID
SELECT TMP
COPY ALL TO C:\GRID3.TXT TYPE SDF
Copy and paste the commands into the command window. You don't need to retype.
I say it will almost do what you want, because this example does the CW mode. If you mean Propagation Mode, which is a user-defined field, then you will need this command instead of the 2nd above:
SELECT DISTINCT GRID FROM LOG WHERE !EMPTY(GRID) AND (LOTW_RCVD="F" OR QSL_RCVD="F") AND CAST(GETUSERFIELD("PROP MODE") AS C(3))="SAT" ORDER BY GRID
