Posts: 20 Location: MEMPHIS, TN
Thanks: 7 times Was thanked: 7 time(s) in 5 post(s)
my 2 email providers are gmail, ,and att ........... both require SSL and a port number to send outgoing emails via their smtp servers. is there a way for me to send outgoing emails from LOGIC given these 2 constraints?
w3bs, buddy
I believe so, have you tried setting it up?
Put in your server and select SSL.
73, Kyle
yes, i tries "ssl" but would also need a place to indicate port number
After the server address, type ":port number" (san quotes)
Example:
my.mail.com:587
thanks. this might work, however gmail blocked the attewpt stating that "a non secure application" was attempting to log in. and recommended that while it could be allowed, that it was not a good idea.
73
buddy, w3bs
What WA4PGM says. This is documented. Hold your mouse over SERVER. Pretty standard syntax too BTW.
