Sorry for the delay in getting back to you on this.
I use a laptop with a Plugable USB docking station, which has the video card hardware for a second display. I reconfigured it as you describe, and cannot find any problem. If I move LOGic to Monitor 2, exit LOGic before disconnecting the docking station and hence the second display, then restart LOGic, it comes up in the main laptop display no problem.
If I remove display 2 while LOGic is running, it doesn't pop onto the main display automatically. I have to click the LOGic icon in the taskbar. It then pops up on the main screen. But it is not maximized, nor do I have to maximize it. The Windows Display Properties window behaves the same way, so I don't think there is any problem with LOGic in my case.
I did discover that if I merely turn off the second monitor, Windows is not alerted and nothing happens. It thinks the second monitor is still there.
What version of Windows are you running? Am using 10 here.
After you maximize it to bring it back, can you then unmaximize it? Are you exiting LOGic first or doing it while LOGic is running?
