Posts: 466 Location: Missouri
Thanks: 98 times Was thanked: 157 time(s) in 139 post(s)
Dennis, the recent Midway and Kure deletions brought up a thought. Is it possible to put a box on the main log form that will show if the entity is deleted at a glance, without having to run a report? 73 Doug W5GA
Posts: 618 Location: Mentor, OH
Thanks: 150 times Was thanked: 235 time(s) in 212 post(s)
Some of the deleted entities have (DEL) added as a suffix to either the DXCC field or the Location field in the Prefix table and so they actually do show up noted as deleted in the Info form. Its not consistent for all deleted entities though. If all were denoted that way maybe that would suffice, or, maybe Dennis could add a check box in the Info form for deleted entities. Good comment !
73 de Brad N8GLS
Groups: Administrators, Beta Testers Posts: 3,249  Location: Auburn, GA Thanks: 1133 times Was thanked: 550 time(s) in 460 post(s)
I will put it in the Info form. Good idea. Will be available in a few days.
The update is there.
