KH2BY (Guam) appears as Untied States
4x1ru
#1 Posted : Wednesday, April 5, 2017 4:12:57 AM(UTC)
There are currently 3 stations active on Guam. AH2P and KH2L show up as Guam. KH2BY shows up as United States. I cannot figure out where this inconsistency is coming from.
Jim 4X1RU
#2 Posted : Wednesday, April 5, 2017 8:30:47 PM(UTC)
It must be a problem with the prefix table. It works here. Install the latest update and select installation of the prefix table. If you want to keep your own, go to tools/prefixes. Look at the GUAM entry. Make sure KH2 is included in the list of prefixes.
4x1ru
#3 Posted : Thursday, April 6, 2017 6:25:56 AM(UTC)
Shalom Dennis,
I reloaded 9.1.13 and permitted the factory prefix list to install. The results are the same. See attached image.
Jim 4X1RU
kh2by - 2.jpg (684kb) downloaded 150 time(s).
#4 Posted : Monday, April 10, 2017 3:53:23 PM(UTC)
Not sure what is going on.
It definitely works here. See my screen shot.
On the info form, try holding the mouse over where I circled. It tells where it got the entry from. Mine says "Info from Prefix". It could be coming from the CTY exceptions file which has a bunch of callsigns with locations that do not match their prefix info. But again, mine works.
Also, look in tools/advanced/path and file info. It could be that you have an extraneous prefix file located somewhere in LOGic's path that is hiding the proper one.
I can get with you on Skype and take a look. Dennis Hevener.
#5 Posted : Monday, April 10, 2017 10:55:45 PM(UTC)
Same result as Jim here as well. I searched the Spot Log for KH2BY and its showing as US. The Info form shows its getting it from CTY.
Brad N8GLS
4x1ru
#6 Posted : Tuesday, April 11, 2017 3:35:52 AM(UTC)
Info form shows the same for KH2 and KH2BY, "DXCC prefix." See attached files.
Not possible to capture via "Print Screen" the comments over the prefix window.
Jim
170411 KH2BY Combined.jpg (120kb) downloaded 145 time(s).
170411 Path File Info.jpg (90kb) downloaded 150 time(s).
#7 Posted : Tuesday, April 11, 2017 7:12:05 AM(UTC)
Don't know if this helps but these are snapshots of KH2 and KH2BY from my Info Form.....
WN4AZY on 4/11/2017(UTC)
#8 Posted : Tuesday, April 11, 2017 9:00:06 AM(UTC)
Ok thanks Brad--
Yours screen shot of KH2BY show that LOGic is getting USA from the CTY file. You apparently have an older version. Check help/about in LOGic. The 9.1.14 version no longer has KH2BY in the CTY file, so it goes to the prefix table as shown in my screen shot.
Jim, FYI you can capture tooltip text with the new Snipping tool. It has actually been around since Win 7. Type Snip in the Win 10 search box. You have to use the DELAY feature. Turn it on, hold the mouse, wait, and when the screen goes gray, lasso the part of the screen you want to capture.
Anyway, try this: Go to tools/setup/prefixes. Click the Binocular button, and enter KH2BY in the CALLSIGN field. That will show the prefix record that LOGic matches with that call.
K8ZM on 4/11/2017(UTC)
4x1ru
#9 Posted : Tuesday, April 11, 2017 10:22:40 AM(UTC)
I had 9.1.13. After updating to 9.1.15 KH2BY is now on Guam.
Thank you Dennis. I had never used the info file before.
Jim 4X1RU
#10 Posted : Tuesday, April 11, 2017 10:39:45 AM(UTC)
Resolved with the later version...(damn, I usually check for that !)
Tnx Dennis....also for the "Del" box on the Info Form, nice !!
Brad, N8GLS
This page was generated in 0.106 seconds.
