4 conductor rotor
w3bs
#1 Posted : Tuesday, March 21, 2017 12:46:48 PM(UTC)
Was thanked: 7 time(s) in 5 post(s)
i have a hex beam antenna controlled by an inexpensive tv rotor, controlled by a 4 conductor wire. the controller display shows me an antenna heading from 000 to 359. can LOGIC interface with such a controller.
thanks
buddy
w3bs
#2 Posted : Tuesday, March 21, 2017 1:13:32 PM(UTC)
Hi Buddy:
LOGic interfaces to all RS-232-controlled rotor controllers that I am aware of. So if someone makes an RS-232 controller for your rotor, you are good to go. But that is probably not the case.
The difficult part is making the hardware interface. Start by searching the web to see if anyone else has done it before.
