Posts: 2 Location: Redding california
I need some help resetting my ts-990s can someone tell me what setting I need on the radio and the program using logic 8 I had it working fine but did a reset on the radio and I failed to save the settings. Thanks Don wa6don
Hi Don:
Do you know what COM port it is plugged into?
Do you know the baud rate of the radio? It is adjustable on most rigs. Dig out the manual and make sure the what the baud rate is.
In LOGic 9, the 990 use the Kenwood_850 driver. Probably the same for 8.
Thank you Dennis, turns out the com port was being used in the data terminal, also the DTR boxes were not checked in Logic 8 in the setup. the driver mentioned above works on the ts-990s so all is well. Don
1 user thanked wa6don for this useful post.
