installed two new fields
w4qnw
#1 Posted : Wednesday, January 25, 2017 12:15:47 PM(UTC)
i have two user fields
one box is blank and has a down arrow which brings up the installed DOK list
IT ALSO HAS A BOX ALONGSIDE WITH THREE ... and the cursor says SEARCH (f2)
This is perfect
the other box bel is for WAB this one DOES NOT have the down arrow or the
three ...(search F2) option.
There is a WAB list established
QUESTION: HOW TO POPULATE THE DOWN ARROW AND THE 3... SEARCH WINDOW
thanks
w4qnw
#2 Posted : Friday, January 27, 2017 10:06:19 AM(UTC)
In tools/setup/log fields, there is an option that says EDIT USING LISTS TABLE. If this is on, it means that there is a list of ALL allowable values in tools/setup/lists of valid values. You would do this for things like DXCC and States.
If this is on, it will provide a dropdown list with the search button.
You would not use EDIT USING LISTS TABLE for anything where all possible values are not known in advance. For example, 1010#. There IS a 1010 list of course, but it would rarely have the newest member in it. So no dropdown list and no search button.
