LOGic Forum
LOGic Support
eQSL
Eqsl error occurred
Posts: 400  Location: Viterbo, VT - ITALY Thanks: 62 times Was thanked: 91 time(s) in 84 post(s)
Hello Dennis, I saw the new procedure of acquiring eqsl.cc at home of my friend IZ0RVI and I was pleased. I tried to receive from eqsl.cc from my computer (XP) and gave me a warning first because I had to login in eqsl.cc. I logged in manually, but the browser told me that it was not possible to download the 15965 QSOs but only a maximum of 10000. I tried to change the date range, and after several trials started the download. I received only 16 qsl and then crashed it. After a few minutes I got this error that you can see in the attached word file. I specify that I have two monitors. What could have happened? I have damaged my file? I await your own advice before continuing. Thank you. 73's de IKØCHU *** IKØCHU Mauro
This error is coming from their server. I recommend contacting them and providing the information requested in the error message.
The 10,000 QSO limit is apparently imposed by eQSL.
I see no reason to suspect that you have a corrupted file or anything wrong on your end.
LOGic Forum
LOGic Support
eQSL
Eqsl error occurred
