Groups: Administrators, Beta Testers Posts: 3,260  Location: Auburn, GA Thanks: 1140 times Was thanked: 555 time(s) in 465 post(s)
I'm not sure how they handle this, but I'm guessing that between the operator field and the QSO Date in LOGic, LoTW can figure it out. LOGic doesn't need to know about the date ranges.
Do you have a separate STATION LOCATION for each call in TrustedQSL, even though they are the same physical QTH? If so, you could export just one call, select the proper station location, and all should be good. Try this if just uploading it doesn't work.
