LOGic 9.0.86 update broke Elecraft K3 interface
KD5M
#1 Posted : Tuesday, May 31, 2016 6:50:51 PM(UTC)
Since upgrading to LOGic 9.0.86 several days ago, the COMM interface to my Elecraft K3 is broken.
It attempts to read the data, but either misreads or shows 00.00 for Frequency and misreads mode - usually reading LSB regardless of actual K3 mode. After several attempts to correct this, LOGic crashes.
How do I go back to the previous working version?? Simply attempting to reinstall a prior version results in error messages.
Please update and fix the error. Prior to this upgrade, it worked very well!
Thanks, Edd - KD5M
KD5M
#2 Posted : Friday, June 3, 2016 8:46:33 PM(UTC)
I should read the text associated with the updates!
Once I read the text about the Elecraft interface and selected polling in LOGic, all appears to be working as it should again.
My apologies for the post and taking up space.
Edd - KD5M
#3 Posted : Monday, June 6, 2016 8:16:58 PM(UTC)
Pse try working a split QSO and let me know if it logs both freqs.
KD5M
#4 Posted : Monday, June 6, 2016 8:55:50 PM(UTC)
Good evening Dennis.
No, it logs the primary frequency but not the split frequency. It doesn't even attempt to fill in the split frequency box.
Edd
1 user thanked KD5M for this useful post.
WN4AZY on 6/7/2016(UTC)
#5 Posted : Tuesday, June 7, 2016 3:09:50 PM(UTC)
Thanks, I'll look at it.
OZ4CG
#6 Posted : Wednesday, June 8, 2016 1:27:50 PM(UTC)
Carsten Gjessing
Hi, Dennis!
Same problem with splitfrequencies with my Kenwood TS590s after the update.
No big problem, but think you should know!
Best 73 Carsten / OZ4CG
#7 Posted : Thursday, June 9, 2016 7:23:53 AM(UTC)
Thanks, I brought that up in another thread.
