9.0.85 Update
#1 Posted : Wednesday, May 4, 2016 8:33:18 AM(UTC)
Dennis, seems like this update has finally made my K3 stable with no crashes! I have only run it a day so far and I have tried everything I can do to crash it, but I've been unable to do so. Very happy that you have finally solved this issue that I have been reporting since I got my K3.
BTW, this update did introduce the problem of the system crashing when saving a QSO, so I had to turn off auto-send, which I didn't even know I had turned on! No problems now.
Thanks again.
...now if you would just RTTY working....! ;-)
ZL4AS
#2 Posted : Thursday, May 5, 2016 4:07:22 AM(UTC)
Thanks for taking time to work on this problem Dennis. I've had it loaded for a couple of days now and not experienced any more crashes. They were becoming most annoying and I was most reluctant to even consider changing to a different logging software.
I certainly was not going to abandon my beloved Elecraft K3!
I had a problem installing .85 when I received an error regarding msver71.dll
I chose to ignore it and all seems OK so far.
I too would appreciate a RTTY interface that works!
73, Cliff ZL4AS
Cliff Gray ZL4AS
QRZ info
