.81 update
#1 Posted : Friday, January 8, 2016 7:43:06 PM(UTC)
Dennis, now .81 is dying. I've deleted prefix.dbf and reinstalled the update, same result. Logic stops working, and crashes.
#2 Posted : Saturday, January 9, 2016 7:52:48 PM(UTC)
My LOGic v .81 just died. I started to log 4Z/3Z9DX on 40 SSB and I couldn't get past 4Z/3 when LOGic died. I get a bunch of error messages and then a Program Error message and then LOGic closes. I re-installed the .81 update and that didn't help either.
I rebooted the pc several times and re-installed .81 and still nada. I also did a cleaned index and still nada.
I get the following error message:
OLE IDispatch exception code 0 from mscorlib: StartIndex cannot be less than zero.
parameter name startIndex..
Then I get these 3 error messages:
The first few messages are:
GLOBAL in not an object (Cancel/Ignore/Help) I hit IGNORE each time.
...and LOGic shuts down.
Everything was working well up until 7:00 pm EST 9-Jan-2016 until LOGic died.
I installed version .80 and .79 with the same results.
Very confused and frustrating. Scared Confused
Vin
ZL4AS
#3 Posted : Saturday, January 9, 2016 9:31:32 PM(UTC)
I am (was) still running .79 when quite suddenly it failed today.
Error was:
OLE IDispatch exception code 0 from mscorlib: Specified argument was out of range of valid values. Parameter name index
A restart then a total close down and restart was no help (re-indexed each time).
An attempt to reload the .79 update appeared not to happen (probably recognised it was already there).
I'm on Windows 10 but beginning to wish I was not !
Also confused and frustrated. Help please Dennis (when you have time)
73, Cliff ZL4AS
Cliff Gray ZL4AS
QRZ info
#4 Posted : Saturday, January 9, 2016 9:50:50 PM(UTC)
I have .79 up and running. Machine is Win7. Uninstalled logic (leave the directory alone!!), reinstalled from CD and applied the .79 update. Working well so far.
#5 Posted : Sunday, January 10, 2016 7:49:05 AM(UTC)
I'm running Win7 as well. I now I have LOGic 9.0.81 working.
The issue for me was when I tried to log 4Z/3Z9DX. LOGic would crash after I started to type 4Z/3 in the Call field. After several uninstalls and re-installs, I was able to deleted the 4Z/3 from the log, entered 3Z9DX/4Z and LOGic plays well with that call.
Not sure why it is but I now have LOGic 9.0.81 running again.
Vin
#6 Posted : Sunday, January 10, 2016 11:16:25 AM(UTC)
That's interesting, Vin. Logic shouldn't care how the call is entered, and in previous iterations it did not.
I was wasn't doing anything at all when .81 died. I had the program open in the background, and all it was doing was receiving spot information from VE7CC. The only thing I had been doing with this particular install is running reports. This isn't the main station PC, it's my laptop, and reports/log extracts to upload to either LoTW or Clublog and watching spots is all this installation is used for.
#7 Posted : Sunday, January 10, 2016 12:07:55 PM(UTC)
I can't explain it. LOGic was running all day yesterday, I logged a few contacts and watching spots on a local node when I logged Dom, 4Z/3Z9DX. All of a sudden, LOGic blew up and I started to get a bunch of error messages.
I've went through too much to fix LOGic so I'll leave it as is and hope Dennis finds a fix. BigGrin
#8 Posted : Sunday, January 10, 2016 7:05:08 PM(UTC)
Are you guys using QRZ.COM per chance?
It was and probably is still causing LOGic to blow up on some calls. However, I can currently log 3Z9DX/4Z with auto callbook lookup on and qrx.com with no problems. If they fixed something, that could explain the seeming randomness.
What is the FIRST error you get?
ETA that I checked the callsigns that were known to cause errors, and they are OK for the moment.
http://www.hosenose.com/...defined-break-point.aspx
#9 Posted : Sunday, January 10, 2016 7:29:35 PM(UTC)
I do not normally use QRZ, but sometimes. I was not using it when .81 died, nor had I anytime in the recent past. I'd like to say that I hadn't used it at all since installing .81, but don't quote me on that. The first error I received is that Logic quit working. After that, every time I start Logic (even after a clean), it would get almost all the way through the re-indexing process, and then quit working again. In fact, it had finished the re-index, and was just getting ready to display a normal log screen, but never quite got there.
Doug
#10 Posted : Sunday, January 10, 2016 8:32:01 PM(UTC)
Since installing v.81, I have not used callbook look ups when logging. I don't have LOGic look up any calls when I'm logging, I have LOGic setup to automatically log name, QTH and Via.
When I first tried to log 4Z/3Z9DX...LOGic only allowed me to get to 4Z/3, and the first error I got was:
Parameter name startIndex..
After that, LOGic blew up.
I would get to a full screen and then the error windows would start popping up and after several "IGNORE", LOGic would shut down.
I'm too scared to try logging 4Z/3Z9DX for fear of going through the nightmare again. I'll keep it as 3Z9DX/4Z since LOGic is happy.
Vin
WN4AZY on 1/11/2016(UTC)
#11 Posted : Monday, January 11, 2016 7:36:46 PM(UTC)
I can reproduce it now. Fix should be here tomorrow. YOU did most of the work already hihi.
#12 Posted : Monday, January 11, 2016 8:44:32 PM(UTC)
#13 Posted : Tuesday, January 12, 2016 8:26:47 AM(UTC)
I'm not going to download it until you guys tell me it;s ok...
#14 Posted : Tuesday, January 12, 2016 9:16:36 AM(UTC)
Running .82 as of last night, so far so good.
Doug
WN4AZY on 1/13/2016(UTC)
#15 Posted : Tuesday, January 12, 2016 9:54:16 AM(UTC)
Pse download it again. The one I posted last night would croak if you logged "/1". I fixed it early this morning. I THINK I tested all possibilities of garbage input hihi.
#16 Posted : Tuesday, January 12, 2016 9:39:39 PM(UTC)
Got it, thanks Dennis.
#17 Posted : Wednesday, January 13, 2016 12:05:23 PM(UTC)
Just installed v.82. Going to try and change 3Z9DX/4Z to 4Z/3Z9DX...wish me luck BigGrin
It worked !!!!! BigGrin
W5RAE
#18 Posted : Wednesday, January 13, 2016 5:20:54 PM(UTC)
Knock on wood, but I have had no issues nor error message since I upgraded to v82.
Thanks for the fixes.
Ron
W5RAE
#19 Posted : Thursday, January 14, 2016 11:05:07 AM(UTC)
Yup. .82 here and no (new) problems.
#20 Posted : Sunday, January 17, 2016 5:17:54 PM(UTC)
All working as it should now with .82
thanks again, Dennis!
Guest (12)
This page was generated in 0.152 seconds.
