"Logic has encountered a user defined break point"
KD0PO
#1 Posted : Friday, January 1, 2016 1:19:21 PM(UTC)
dokxray
and will be shut down.......
not sure what that means, but it appeared with version 79 when I added a Q this morning and tried to do a logbook search. I updated to ver 81 and it's still there???
any Ideas???
Ray
KD0PO
#2 Posted : Friday, January 1, 2016 1:42:04 PM(UTC)
dokxray
windows 10 all latest updates
if I type "TK5MH" into the call book search or the QRZ window in the call book it crashes. I can type my call or other "K" calls in and no problems???
Ray
#3 Posted : Sunday, January 3, 2016 7:23:51 PM(UTC)
Hi Ray--
It's something funny with qrz.com. I can reproduce it here. It's probably just this call that it does it on. I looked up several DX and K calls on QRX.COM with no problem. I think it is the weatherunderground.com that TK5MH has on his Biography area area. The windows event log says:
Faulting application name: LOGic.exe, version: 9.0.81.0, time stamp: 0x47139f24
Faulting module name: KERNELBASE.dll, version: 10.0.10240.16384, time stamp: 0x559f3b2a
Exception code: 0x4000001f
Fault offset: 0x00132bd2
Faulting process id: 0x2e0c
Faulting application start time: 0x01d14685aef1d7d8
I'll do a little debugging and try to see if I can find what is causing it, but HamQTH.COM works. It is designed for programmatic access, so I recommend that or the paid QRZ paid XML subscription.
Dennis WN4aZY
KD0PO
#4 Posted : Monday, January 4, 2016 2:52:13 PM(UTC)
dokxray
I hope you're having a great 2016.
There were several other problem calls from this week ends RTTY contest.
XE2K, XE1XR, PU5AEC and others I don't recall.
It was so surprising, I'd never had that happen before. I tried them again today thinking it was just a temporary problem with QRZ, but it is still there.
If there is any testing I can do, or addional info you need let me know.
Thanks again for a great product,
Ray
#5 Posted : Sunday, January 10, 2016 7:09:25 PM(UTC)
QRZ.COM seems to be working with these callsigns, for the moment anyway.
73, DH
KD0PO
#6 Posted : Thursday, January 14, 2016 7:40:17 PM(UTC)
dokxray
Yes, everything is good now. Thanks again...
