80 Update
NU1B
#1 Posted : Thursday, December 17, 2015 5:25:49 PM(UTC)
Hi Dennis
I downloaded update 80 and installed the update on my computer
When I started Logic, Logic did the indexing and then I get a message from Windows indicating Logic has quit working and is being shutdown. I downloaded update 80 again and reinstalled the update but got the same result.
I then tried to reinstall Update 79 but got the same result. I then did a system restore back to set point about 1 hour before I tried to install Update 80. The system restore restored Logic to version 79 & everything is working fine
Any ideas what my problem may be with Update 80
73
Steve, NU1B
#2 Posted : Thursday, December 17, 2015 7:49:21 PM(UTC)
Hmmm, don't know. I found an old machine with .74 on it, installed .80, and it was fine. And I see several others have downloaded it already.
Let me put together a complete .80 install, and get that to you tomorrow. Something else could be corrupted. You could also check your disk for errors, and go to a DOS prompt and type
SFC /scannow
Sri for the problem.
#3 Posted : Friday, December 18, 2015 7:31:33 AM(UTC)
I updated LOGic from 79 to 80 and now when I log a contact I get an error message.
If I IGNORE it, it shuts down LOGic, if I hit CANCEL, I can log the contact.
LOGic 9.0.80 logging error.jpg (25kb) downloaded 125 time(s).
#4 Posted : Friday, December 18, 2015 9:57:25 AM(UTC)
Hi Vin:
I would like to log into your computer and see if I see anything. I tried calling you just now. Hope to catch up with you later.
#5 Posted : Friday, December 18, 2015 2:04:50 PM(UTC)
I left you a message on the tech support number. Sorry I missed your call. I should be free after 3:00 pm eastern today or we can give it a try on Monday.
Vin
NU1B
#6 Posted : Friday, December 18, 2015 6:41:01 PM(UTC)
Hi Dennis
I ran SFC/scannow as you suggested and did not find any problems
73
Steve, NU1B
W5RAE
#7 Posted : Saturday, December 19, 2015 1:11:42 PM(UTC)
I had to do the same things happen that NU1B did after installing v80. Worked ok once first installed but after shutting program down, would stop working on restart. Back on v79 after system restore.
Ron
W5RAE
W3KL
#8 Posted : Saturday, December 19, 2015 3:02:03 PM(UTC)
I'm seeing the same problem here
I have the latest .NET framework.
Windows 8.1
73
W3KL
#9 Posted : Saturday, December 19, 2015 3:07:28 PM(UTC)
Ok. Tried to drop back to 79. Now when I start up I get the same OLE error reported earlier:
OLE error code 0x80020006:Unknow name.
Clicking cancel or ignore doesn't help, nor does re-booting.
Looks like we are dead in the water.
Please help
W3KL
#10 Posted : Saturday, December 19, 2015 4:02:57 PM(UTC)
Was finally able to get 79 running again, but I had to drop back to a restore point from yesterday.
#11 Posted : Tuesday, December 22, 2015 6:02:26 PM(UTC)
Fixed now. Pse download and install the .80 update again.
http://www.hosenose.com/...?find=lastpost#post5410
#12 Posted : Tuesday, December 22, 2015 9:18:39 PM(UTC)
Does this fix the error I was getting too?
"OLE error code 0x80020006:Unknown name"
Vin
W5RAE
#13 Posted : Thursday, December 24, 2015 12:52:54 PM(UTC)
I installed the "new" v80. Worked ok once when first installed but after shutting program down, would stop working on restart. Back on v79 after system restore.
Ron
W5RAE
#14 Posted : Thursday, December 24, 2015 1:32:43 PM(UTC)
w5rae: Same error after restart?
k1vc: Did you have additional errors since I logged into your system?
Merry Christmas & 73,
W5RAE
#15 Posted : Thursday, December 24, 2015 3:07:41 PM(UTC)
All working okay now.
Merry Christmas.
Ron
W5RAE
#16 Posted : Thursday, December 24, 2015 8:33:46 PM(UTC)
I had to reinstall from CD and update with .79 to get the program to run.
#17 Posted : Saturday, December 26, 2015 8:29:48 AM(UTC)
Still having the error message when I log a contact with a reinstall of v80.
Vin
W5RAE
#19 Posted : Monday, December 28, 2015 4:19:16 PM(UTC)
I was hasty in saying the problem had been fixed. When I installed the "new" v80 with the prefix table update it worked ok once when first installed but after shutting program down, would stop working on restart, even doing a clean before the restart. Troubleshooting, I made a copy of the prefix file database after the v80 install and before I started the program (the only thing I had done different before). I started reinstalled v80 program okay, then shut it down and tried to restart the program, the program stopped working on restart. I then ran clean again, deleted prefix db, copied my backup v80 prefix db file as THE prefix file. Restarted program and it ran okay. I think there is an issue with the prefix database after it is updated/indexed on restart of Logic9.
Your thoughts?
Ron
W5RAE
#20 Posted : Monday, December 28, 2015 4:55:39 PM(UTC)
Hi Ron:
Are you saying there is a problem with the factory prefix table after you install it and reindex it? When I called, we deleted the existing prefix table, installed the .80 update, and restarted several times. I don't recall if we reindexed or not tho....
I just now tried on a non-development machine. Deleted prefix.dbf, installed the update (now .81 but the same prefix table), cleaned, restarted/reindexed, and all is good.
Here's an idea: Search for another Prefix.dbf table. There should be one prefix.dbf table in the DATA folder. If there are any others, LOGic could be picking that up instead of the one it is supposed to. I think the update installer clears prefix.dbf out of the install folder if it finds one there, but there could be others. Also search and destroy prefix.cdx and pfxndx.*. These all get recreated when you clean.
Vin: I fixed the error you reported when we talked. Get the .81 update.
Doug: Try the .81 update. If no go call me or let me know and I will call you.
W5RAE
#21 Posted : Monday, December 28, 2015 6:15:02 PM(UTC)
Yes, I was only using the factory prefix table but now it keeps dying on me no matter what I do with the prefix database. Tried v81 too and it did same thing. Reinstalled v80 after clean and program restarted but says it is version 81, not 80 which is the one I just reinstalled. Don't want to shut it down now since issue is back.
Ron
Guest (10)
This page was generated in 0.120 seconds.
