Adding Log field that is not user defined
W8CFI
#1 Posted : Saturday, December 5, 2015 7:46:05 AM(UTC)
Is there a way to add a listed Log Field to a custom log that does not show up as user defined? I am trying to add the YL System TFO# which is listed as a log field to a custom log. In other words is there a way to get it to show up in the "Select user defined fields" box for adding to the log?
Thank you.
#2 Posted : Saturday, December 5, 2015 8:50:25 AM(UTC)
Hi,
If your referring to the YL# field that already exists in lOGic then you should see it after clicking on the "little man" radio button at the bottom right of your log form. This will bring up the select user defined field set up window, the right side is the list of user available fields, scroll down to the bottom of it and that's where the YL# field is at. See attachment.
Brad, N8GLS
W8CFI
#3 Posted : Saturday, December 5, 2015 8:54:50 AM(UTC)
Thank you Brad, I fould the YL# but would also like to be able to add the TFO#
#4 Posted : Saturday, December 5, 2015 12:43:07 PM(UTC)
OK on YL#, I see the logfield for TFO#. Looking at the logfield I see that its the only logfield where the enabled checkbox in the logfield screen is both unchecked and grayed out as well, like its not available. I haven't run into a log field instance like this one so will have to revert to Dennis or others here as to why its not visible or selectable in the logform.
Sorry I couldn't be of more help!!
Brad, N8GLS
WN4AZY on 12/7/2015(UTC)
W8CFI
#5 Posted : Saturday, December 5, 2015 12:46:40 PM(UTC)
Thanks again Brad, I notice a couple like that.
73, George
This page was generated in 0.157 seconds.
