Groups: Registered, Beta Testers Posts: 503 Location: Richmond, TX
Thanks: 44 times Was thanked: 88 time(s) in 83 post(s)
Dennis, are there any prefix updates after this one that may have overridden E6? 73, Allen N5XZ
It SHOULD be in the .72 or .73 update. Is it not?
Posts: 474 Location: Missouri
Thanks: 103 times Was thanked: 161 time(s) in 143 post(s)
WN4AZY;5107 wrote:It SHOULD be in the .72 or .73 update. Is it not? Not so you'd notice. 73 Doug W5GA
I deleted E6 from my prefix table, installed this http://www.hosenose.com/...and-fixes.aspx#post4797
and tada, E6 came back. Be sure to checkmark the option to install the prefix table update when installing. Tnx/73, Dennis WN4AZY
Dennis, your link isn't working on the forum page. It does work in the email notification. However, the fix doesn't work. I've attached a screen shot after doing as you suggest. And Yes, I checked the box for prefix table update. The screen shot is after hitting the tab key. 73 Doug W5GA
Thanks for the pic. The problem is the DXCC list.
Go to tools/setup/lists of valid values. Navigate to DXCC ZK2 Niue. Click CHANGE VALUE. Enter E6
Exit and restart LOGic.
