LOGic Forum
LOGic Updates
LOGic 9 Updates
QRZ informations don't work anymore
Hello Dennis, QRZ subscription informations don't work anymore on my side since to day and i got a the following attached fault.  73's Michel VE2XK
Did it just stop working? If you haven't tried the usual -- exiting LOGic & rebooting your computer, do that. Did you make any changes to the computer? Try turning off USER ACCOUNT CONTROL. Also, run LOGic as Administrator (right-click the LOGic shortcut).
Does anything show up in the web browser window? Try to right-click and VIEW SOURCE.
Posts: 41 Location: Torrington, Ct
Hi Dennis
I am having the same trouble with QRZ. I get the same error listed above. I have tried the items that you listed above and still have the same results
My QRZ was working & I have not made any changes to my computer
I appreciate any suggests in how to fix
73
Steve, NU1B
Posts: 2 Location: Salem, NH
Hello Friends, I am having the same problem regarding my QRZ Subscription service. With my System that runs Windows XP - I am getting the following msg. Error 13 "Alias 'QRZTMP is not found ." has occurred in program CALLBOOK_WEB_ASYNC_SUBSCR, line 176 Respectfully, Carmen - K1LKP
Groups: Registered, Beta Testers Posts: 491 Location: Richmond, TX
Thanks: 43 times Was thanked: 86 time(s) in 81 post(s)
I had the exact same problem. Even IE wouldn't work on it's own. I rebooted the machine and after a few minutes it all worked again... Who knows why...? Anyway, it is working again at my station now. 73, Allen N5XZ
Good Morning Friends, Everything appears to be working just fine. It must of been the GHOST of HoseNose that created this problem. Go Figure. Have A Fun Filled Day 73 K1LKP Carmen
Next time it happens, look in the web browser section of the callbook window and see if it says anything.
It's working here at the moment. I suspect QRZ had something going on.
I beefed up the error checking and reporting, so next time, maybe....
Hi Dennis
Just want to let you know my QRZ information is now working. Did not make any changes to computer
73
Steve, NU1B
LOGic Forum
LOGic Updates
LOGic 9 Updates
