LOGic still does not import SKCC numbers and C/T/S properly
KB7EEG
#1 Posted : Saturday, May 23, 2015 3:51:23 PM(UTC)
Hello Dennis, we talked this weekend abt this and the troubles I was having getting LOGic setup to show SKCC#'s etc.. Well now that part is done, but now the problem is it will not import any SKCC numbers at all when I try to import an ADIF File that has the SKCC # and C/T/S together. It just drops it all together. I don't wanna have to be running 2-3 programs to log with because one will not do what the others will do, HELP.
Chris
KB7EEG
#2 Posted : Tuesday, May 26, 2015 1:53:52 PM(UTC)
Hi Chris:
I think all you need to do is go to the field in tools/log fields, navigate to that field, and map the name in your ADIF file to what you are using in LOGic.
There is also a checkmark that controls whether the field is imported when you do the basic fields. May as well turn that on to make sure.
