current updated table
KD0PO
#1 Posted : Wednesday, January 2, 2002 3:42:04 AM(UTC)
dokxray
where do I (or can I) download the current awards and prefix tables?
thanks...
#2 Posted : Wednesday, February 18, 2015 6:45:52 PM(UTC)
G'Day,
I am assuming the date of your post is an error somewhere ...
There is no "complete" download for awards data. A set of typical award lists is supplied with LOGic, after which it is your responsibility to maintain your own award lists.
That sounds a bit tough. But, LOGic allows you the freedom and ability to create and maintain your own custom Award lists and User defined fields. Your custom lists will be included in all progress reporting.
If you create an award list, share it on the forum, as others have done. You can easily export/import award lists to exchange with others.
Search the forum for "award". Or simply look back through the older topics in this particular forum.
N7IP
#3 Posted : Thursday, February 19, 2015 6:37:31 PM(UTC)
How do we get a copy of the latest factory prefix table?
Also, I added K1N to my table, but now any K1Nxx gets tagged as KP1. How should I have entered K1N in the prefix table to avoid this?
#4 Posted : Thursday, February 19, 2015 8:12:35 PM(UTC)
G'Day,
Download and apply, re-apply, the latest LOGic 9 update. Answer YES to update the Prefix table.
If you created "user records" in the Prefix table they will be preserved - provided you are using LOGic 9.0.59 or above. If you modified a "system record" in the Prefix table, or you are using an older version of LOGic 9, the system record will be overwritten.
Update your entry so K1N has a trailing "underline" - K1N_ - then only K1N will be found for that entry.
Search Help for "underscore" and look in the entry for Prefix Table. Searching is described in the first few paragraphs.
See also ...
Overwrite Prefix Table
WN4AZY on 2/22/2015(UTC)
