For some reason I'm not able to post in the bulk data change and database commands section so asking here. I have many qso's with QSL sent=R and QSL received=R and LOTW received=F. I want to change QSL sent and received to blank when LOTW received=F. In the advanced database area I'm not sure what to put in the replace this field with to change it to blank. I think it should be "". Thanks for any help with this. Rick AK3E
Hi Rick: If I follow you, this is what you want: Quote:USE LOG
REPLACE QSL_SENT WITH " " FOR LOTW_RCVD="F"
REPLACE QSL_RCVD WITH " " FOR LOTW_RCVD="F" Make a backup first just to be safe! Tnx/73, Dennis WN4AZY
