Sorry, I am not seeing a problem here. How is it labeled?
The RTTY designation has changed to DATA (to be compliant with ARRL LoTW), moving phone to the lowest position on the form. But it still works. Double-click on anything in the PHONE row, and USB or LSB QSOs come up. Double-click anything in the DATA row, and RTTY QSOs come up.
If this isn't what you are seeing, try awards/update awards progress info.
If you don't like the DATA designation, change it to RTTY in tools/setup/modes. Then run awards/update awards progress info.
