Posts: 63  Location: Winthop, WA Thanks: 5 times Was thanked: 9 time(s) in 9 post(s)
When I try to export the CQ WW cw log to Cabrillo, I get the template for the Sweepstakes contest. How do I get the correct template for this contest?
Hi-- It should use the OTHER template. You can change it by clicking Setup index the Log dropdown menu in the log data form. I am attaching mine in case there are other changes. Unzip into the logdata\logforms folder. Happy tnxgiving all! 73, Dennis
Thanks Dennis for the prompt reply. Found the "other.cabrillo" and got it set up.
Again, Thanks and 73, Ron
By the way, I found it by going to Log - Setup - contest setup - Cabrillo tab - then in the box for Cabrillo Template, I clicked the little box to the right and it took me to a list of files where I clicked on Other.cabrillo.
Worked slick. I may yet figure out this program.
73,Ron
