LOGic Forum
LOGic Support
Spotting
Spot Comments from Telenet Window do not show in Spot Log
Posts: 32 Location: Minnesota
Sometimes the comment field data coming from my Telnet connection does not display in the Spot Log. This occurs only when the comment is long, and fills up the entire field. I think this is 30 or 31 characters. In this case the comment field in the Spot Log is blank. The comment field reads ok in the Telnet window, it disappears on its way to the Spot Window. If the number of characters in the comment field is less than maximum, then they display correctly.
Groups: Registered, Beta Testers Posts: 503 Location: Richmond, TX
Thanks: 44 times Was thanked: 88 time(s) in 83 post(s)
I observe the same thing. 73, Allen N5XZ
LOGic Forum
LOGic Support
Spotting
