Sending a DX spot
N9BBE
#1 Posted : Thursday, September 8, 2011 11:00:16 AM(UTC)
I'm using the latest build of Logic8 on WIN7/64 bit. I'm having a problem sending spots.
The spots never show up on the cluster. Sending from the log window or the telnet window
doesn't matter. Been having this problem for quite some time. I don't post a lot of
spots so it hasn't been a big deal but I would like to find out what is causing the
problem. Thanks in advance.
#2 Posted : Thursday, September 8, 2011 8:16:29 PM(UTC)
Do you have your call configured in the main program options?
#3 Posted : Monday, September 12, 2011 10:20:43 AM(UTC)
The forms input on DXSummitt is a bit dicey -- not positive that that works. However, Telnet should be straingtforward. What shows up in the transmit window of telnet? As I recall it should say
DX DE WN4AZY: 14123.4 DU2DX Strong sigs
N9BBE
#4 Posted : Wednesday, September 14, 2011 12:34:41 PM(UTC)
TNX for the replys and sorry I haven't been back for a few days to check.
Yes, I do have my call configured in the main program.
Dennis, I'll check when I get a chance and get back with the details.
Thanks again...
N9BBE
#5 Posted : Monday, December 19, 2011 2:17:22 PM(UTC)
Well, need to check the forum more then every 3 months...MY BAD.
Dennis, I did want to let you know I switched from spotting from DXSummit
to a regular telnet site. I tried a few of them and seems like teleneting
works fine for posting spots to the cluster. Actually get the spots on a more
regular basis. Thanks and sorry for not checking here on the forum a little
more often. Patiently awaiting V9.
#6 Posted : Tuesday, December 20, 2011 9:00:57 AM(UTC)
No problem!
Seems to me that a local Telnet cluster would be the way to go -- the spots would be most relevant.
