LOGic Forum
LOGic Support
Spotting
20 and 40 meter CW spots not appearing on Spot Log
I have not been receiving 40 meter CW spots for a long time in the spot log. Today I noticed that 20 meter CW spots have started to not appear in the spot log. I can't live with that.
Logic is acting just like I have the band filters set up to not show the 20 or 40 Meter CW spots.
There are NO filters set.
When I look at the band setup the box to process CW spots is checked for both bands and the frequencies are set like I want them to be. The 1234 numbers for what I want to display are set up like the bands that are working.
When I try a test spot it does NOT display when the spot is on a CW frequency on 20 or 40 meters (the other bands are fine).
There are no Pre-filters set.
I should add that the alert feature works just like it should. It does announce 20 meter CW spots when the spot matches the alert filters.
Does anyone have an idea where I go from here?? I need my 20 meter CW spots!
73, Bill W7OO
Hi-- The way you describe it, it should be working. Make sure SHOW ALL SPOTS is checked. Run thru this list, http://hosenose.com/Foru...ng-in-the-spot-log.aspx
and if that doesn't resolve it, call me and I can log into your computer and take a look. Also check the frequencies in the band table for 40 & 20. Let me know. Tnx & 73, Dennis WN4AZY
LOGic Forum
LOGic Support
Spotting
