Can't get FO/UT6UD to log in correct country
W7OO
#1 Posted : Tuesday, July 16, 2013 12:37:38 PM(UTC)
I am having a problem getting QSOs with FO/UT6UD to go to the correct country in LOGic.
Here is what is happening:
I have worked him two times when he was using the FO/UT6UD call from FO-F.
He has now moved to FO-A and is still using FO/UT6UD. I have tried to add FO/UT6UD to the prefix table under FO-A but new QSOs are still logging as FO-F when I add them.
I have tried running Update Awards with no change.
What do I have to do to get future QSOs with FO/UT6UD to log as FO-A?
I do understand that I can change the country under MAIN DXCC for individual QSOs.
Thanks for any insight you can give me on this.
Bill
W7OO
#2 Posted : Tuesday, July 30, 2013 10:51:26 AM(UTC)
Hi Bill--
Sorry so long. Don't see how I overlooked this one, but I did.
To make an exact callsign with portable match, you have to suffix it with _
So try FO/UT6UD_
I will add this to mine.
http://hosenose.com/Foru...ssian-prefixes-easy.aspx
