Kenwood TS-990S
ki0kb
#1 Posted : Thursday, June 20, 2013 1:45:48 PM(UTC)
I'm using a new TS-990S and it works well with the TS-2000 utilized for the rig except for the PSK mode which it defaults to LSB when logging. Is there any other Kenwood rig that would work better or is the PSK mode just not on any of the other Kenwood rigs? Any suggestions?
Thanks Jeff / KI0KB
#2 Posted : Friday, June 21, 2013 4:44:21 PM(UTC)
Hi Jeff:
Do I understand correctly that your rig is a TS-990S, and you are using the TS-2000 driver in LOGic 9?
If this is your situation, make sure you are using the non-legacy TS-2000 driver in LOGic, not the one that says "(legacy)" after it.
Does the rig have a PSK position on the mode switch, or are you using LSB? This is the case with most rigs.
The way to work with this in LOGic is to enter the "modes returned by the rig" in radio setup
USB,LSB,CW,AM,FM is typical. Then manually log PSK when you are working PSK. LOGic will stop reading the mode from the rig until you manually log a mode listed in "modes returned by the rig". Look at the help for that screen.
ki0kb
#3 Posted : Friday, June 21, 2013 7:04:22 PM(UTC)
I am using the TS-990S. I have switched to a non-legacy driver although there was no non-legacy driver for the TS-2000 specifically that I could find. I am now using the Kenwood 940, 480, etc. non-legacy driver. I did enter into the Modes box the following: USB,LSB,CW,AM,FM,FSK,PSK.
The TS-990S does have a mode button for PSK which is read as LSB by Logic. Once I manually change to PSK it will stay there for subsequent contacts as you indicated until I switch modes which it seems to do automatically when I change modes. The FSK mode button is read as RTTY by Logic.
I can certainly live with that but it would be nice if at some point it could be recognized as PSK for logging purposes by Logic. With this new rig and it's abilities I find myself switching back and forth frequently between CW, RTTY, PSK and SSB and often for just a single contact or two. Since I have been used to Logic following my previous rigs without fail, non of which I did digital on, I will often miss that the mode did not follow in PSK until later. Now that I know the issue I'm usually on top of it but initially it caught me napping.
Anyway, great product and thanks for replying to my question.
Best 73 de Jeff / KI0KB
#4 Posted : Wednesday, June 26, 2013 8:14:38 PM(UTC)
Can you direct me to the programming commands for the 990? I found the manual but it does not have it -- unless I overlooked it.
http://kenwoodusa.com/Us...AMA/Manuals/TS-990s.pdf
ki0kb
#5 Posted : Thursday, June 27, 2013 11:57:59 AM(UTC)
This should be the link to the PDF file for the TS-990S Programming Command Codes. I can see why they didn't put it in the already 300 plus page manual.... Jeff / ki0kb
http://www.kenwood.com/i.../ts_990_pc_command_e.pdf
#6 Posted : Thursday, June 27, 2013 2:01:42 PM(UTC)
Ok, that's what I need. Thanks!
