Some explanation is needed for this report.
This report is showing LOTW received as well as paper. The QSL R status shows the best of LOTW and paper. So from 6M G I see that you have worked it, but have not received a QSL, paper or LOTW. If there were an R here (Requested), I would know that you marked a 6M G QSO with R in either LoTW or paper or both. I just can't tell which by looking at this report.
You will never see a Fulfilled here because if an entity is confirmed, it will not appear on this report.
For QSL S, that column looks at paper only. All QSOs are presumed to have been sent or will be sent to LoTW.
