Spot Log modification
KA1J
#1 Posted : Thursday, November 29, 2012 7:02:00 PM(UTC)
I've worked EY8MM on 160 but the spot log showed I needed it on 160 to satisfy a needed CQZ 17.
I remembered working him and getting a LOTW confirmation of that.
I looked up his call & sure enough I worked him in 09 and he was CQZ 17 but
the Spot log is showing him as needed on 160.
earlier QSO & current spot log
Perhaps the issue is LOTW results may not be filtered in from the "Spot Level"
settings under options? The three options to filter out a call from showing
as needed are QSL received, QSL requested & has been worked.
I want to be notified if I have no confirmation on that band but a LOTW is just fine for DXCC.
Thanks!
Gary
#2 Posted : Friday, November 30, 2012 9:21:54 AM(UTC)
Ok, you have him for DXCC, but the spot shows that it is needed for CQ Zone (WAZ). Your spot log is correct. LoTW doesn't count for WAZ. There is a setting in tools/setup/log fields to determine whether LoTW counts or not.
