Problem with install
N7EO
#1 Posted : Monday, November 26, 2012 7:22:26 PM(UTC)
No clue what happened but had a problem getting the .49 to run. I updated from .47
After an hour of playing with it I compounded the problem by doing a complete uninstall of LOGic9.
Logic9 was installed over a Logic8 installation.
I've reinstalled from my disk with the Logic.exe dtd 12/05/10 and get two error messages.
1) Error 1426 "OLE error code 0x80040154: Class not registered" has main, line 0. If continue selected get:
2) Error 1924 "Global is not an object: has occurred in program main line 0. If continue selected get:
Momentary NBS time check clock correction screen flash and no LOGic program display.
If I do a fresh install and replace the old Logic.exe with .49 I get the same results.
Task manager processes show Logic.exe*32 running with 13.8k memory use.
I'm running Win 7 Ultimate SP1 on a Dell Precision w/Xeon and 6g ram.
TIA
Gene
#2 Posted : Monday, November 26, 2012 8:18:20 PM(UTC)
You have to install the .48 update first, then download the .049 logic.exe.
Sorry, I'll put a note there.
