LOGic Forum
LOGic Support
Spotting
spot log incorrectly flagging entities/zones etc
Posts: 474 Location: Missouri
Thanks: 103 times Was thanked: 161 time(s) in 143 post(s)
Dennis, just noticed this. I have ZP6CW confirmed via LoTW on 12m CW. The spot log flagged me for still needing CQZ 11 on 12m cw. This is just one example. Thanks Doug 73 Doug W5GA
Ok, does the Progress display show it correctly?
Does the spot log show 12M & CW as UNDERLINED in the spot log?
Try tools/update awards progress info. Then post a test spot like the one in question.
Hard to say, as the progress forms don't display CQZ. When I do a DXCC report, or a CQZ report, all comes out as it should. I routinely update the awards progress info, as I run LOGic on 2 machines, one for real time in the shack and one on my laptop to peruse at leisure. 73 Doug W5GA
Well, just switch Progress 1 or Progress 2 to CQZ. I ask this because these use the same table that the spot log uses to determine status.
Yes, spot log shows this as underlined for both 12m and cw. Progress shows cqz 11 as worked, not confirmed. QSL status for ZP6CW is confirmed via LoTW on 12m cw. The last award progress update was done tonight. 73 Doug W5GA
LOGic Forum
LOGic Support
Spotting
