Posts: 36 Location: Utah
I can log in to my QRZ pages from a browser but LOGic is giving an error "OLE IDispatch exception code 0 from msxml3.dll; Access is denied" I have not changed my password on QRZ.
Broken!
Mark
Posts: 2 Location: Cantonment FL USA
Originally Posted by: W7HPW  I can log in to my QRZ pages from a browser but LOGic is giving an error "OLE IDispatch exception code 0 from msxml3.dll; Access is denied" I have not changed my password on QRZ. Same here. Gene N7EO
Posts: 8 Location: Ft Myers FL
Same here.. QRZ subscription not working
I have the same problem here QRZ not working in subscriptions
Posts: 2  Location: Prior Lake, MN
I have the same issue with the current Logic update.
Posts: 1 Location: ireland
Hi,
Same problem here (I use Logic version 9.0.45/ Windows 7 OS)and I could not access QRZ Subscription this weekend, I reinstalled an older Logic 9 version 9.0.39 this afternoon to see if it would access QRZ Subscription but it also failed and resulted in the error Mark mentions. I have no problem with accessing the service via QRZ website so maybe QRZ have altered some parameter?
Patrick, EI4IR
Groups: Administrators, Beta Testers Posts: 3,257  Location: Auburn, GA Thanks: 1135 times Was thanked: 553 time(s) in 463 post(s)
Please guys, when you have problems like this, check for updates: http://hosenose.com/Foru...px?find=unread#post1703
Tnx & 73, Dennis WN4AZY
I did try that up date but it will not work with my LOGIC 8 seems that it will only work with 9
Are you going to update Logic 8 to fix the QRZ Problem?
Posts: 1  Location: Northglenn CO
I am having this problem and just recieved a reply from QRZ which will follow. Unfortunately they did not say how to implement it. I am assuming there will have to be a patch to do it.: We recently updated our XML server. The new address you will need is: xmldata.qrz.com. We apologize for any inconvenience. We have updated all of the software companies to let them know about the new address but not all of them have made changes. We thank you for your patience.
Marv....W0ZK
