Error message when trying to spot 6m contacts
AK3E
#1 Posted : Saturday, June 2, 2012 8:24:45 PM(UTC)
I have the same results with DX Summitt and Telnet with various hosts. When I try to spot a station I have worked on 6m I get Program error Property LATITUDE is not found. I then click on ignore I get Operator/operand type mismatch. Click ignore and then I can post the spot. If I click on cancel on either of these errors I have to use task manager to close Logic 9. Also when I exiting Logic for any reason I sometimes get and error message something like global not found(I can't seem to duplicate it right now). I also had this problem on exit with Logic 8, just lived with it. Thanks for any help.
Rick AK3E
#2 Posted : Saturday, June 2, 2012 10:03:55 PM(UTC)
Ok, do you get this only on 6M? Where in LOGic are you posting the spot from?
Reinstall the latest update. Even if it is already installed, sometimes it fixes things.
AK3E
#3 Posted : Saturday, June 2, 2012 10:25:32 PM(UTC)
I closed all programs, rebooted the puter, re-installed the latest update(.43) rebooted again. I do not like DX Summitt so I use the telnet window. Using the very left icon on the telnet window for sending DX spots. I can high lite any hf station in my log, 10m and below and all works fine. 6m, 2m, 70cm and above all give the before mentioned errors.
Rick AK3E
#4 Posted : Tuesday, June 5, 2012 11:42:02 AM(UTC)
Thanks -- I fixed it. Will be in the next update.
#6 Posted : Monday, July 16, 2012 8:37:02 PM(UTC)
Fixed in 9.0.44.
Thanks!
This page was generated in 0.105 seconds.
