USEFIELD limit - missing data
#1 Posted : Tuesday, August 4, 2026 10:32:23 AM(UTC)
I have been adding several user defined fields and I noticed that USERFIELDS in many records now has only part of the user defined field data, i.e., |LOTWRDATE:20260804| would appear in USERFIELDS as |LOTWRDATE:20260 so its being cuttoff. I see where when this occurs the date in the logform for LOTWRDATE is blank. I know I have exceeded the 244 character limit for USERFIELDS but thought USERFIELDS(2) would pick up the entire pipe not just extend the characters from USERFIELDS. How can I fix this ??
Update: So I filtered the log to show only USERFIELDS > 240 characters and got 13 QSO records. I could delete a user defined field or two but curious how USERFIELDS and USERFIELDS2 actually work. If you add more userdefined fields to a record where the 244 character limit gets exceeded by less than the # of characters in the pipe, does the entire pipe get moved to USERFIELDS2 or does the userdefined field just get split between USERFIELDS and USERFIELDS2 ?? Say I add userdefined field JUNK and it can contain 10 characters ( JUNK:0123456789 ). If that QSO record has 240 characters in USERFIELDS will JUNK get split between both USERFIELDS ( |JUNK goes into USERFIELDS and :0123456789| goes into USERFIELDS2 ) or does the entire pipe |JUNK:0123456789| get put to only USERFIELDS2 ??.
Sorry, I may have asked something like this years ago but can't find all the threads.
#2 Posted : Wednesday, August 5, 2026 12:25:06 PM(UTC)
AFter more investigating;
Ok, USERFIELDS spills into USERFIELDS2 when USERFIELDS character count exceeds 244 characters. However, when USERFIELDS spills into USERFIELDS2 the spilled field does not show up in the browser or in reports. I tested this by clearing some user defined fields and the browser and reports show fine, if I add back user defined fields whatever is spilled into USERFIELDS2 does not show in the browser and reports.
Different issue: I found it odd when filtering the log for LEN(ALLTRIM(USERFIELDS))>240, of 13 QSO records only 6 of them spilled into USERFIELDS2, the other 7 records showed nothing spilling into USERFIELDS2.
#3 Posted : Monday, August 17, 2026 7:07:37 PM(UTC)
Sorry for the delay. I have been out of town. Just wanted you to know that I will look at this soon.
#4 Posted : Thursday, August 20, 2026 4:34:01 PM(UTC)
Still investigating this. But I think adding USERFIELDS and USERFLDS2 to the browse window would be helpful.
Note: The USERFIELDS log form shows both USERFIELDS and USERFLDS2.
What report(s) is not showing the extended USERFLDS2 properly?
#5 Posted : Friday, August 21, 2026 8:58:21 AM(UTC)
Sorry for your loss !!
I havent tried every report but the awards report was the one I was looking at. I attached a pic showing the logform with userfields and userfields2 and you can see if a field spills into userfields2 it doesnt show up in the browser window.
missing data1.png (287kb) downloaded 5 time(s).
